A UDF for mixture outlet variable derived from two other input parameters?
Old   July 12, 2017, 03:17
Default A UDF for mixture outlet variable derived from two other input parameters?
ali
ebtedaei is on a distinguished road
Hello. I'm using a multi-phase model. I need to write the UDF function for an output variable (derived from two other input parameters of each phase).
But this variable does not exist in the inlet boundary conditions, so I can not add the udf function to the boundary conditions!!!
what should I do? Thank you for advising.
ebtedaei is offline   Reply With Quote
Pro/E to ANSYS Parameterization Guide Trues ANSYS 4 April 18, 2018 06:52
UDF of Variable Porosity typhoon1010 Fluent UDF and Scheme Programming 3 October 4, 2016 06:00
emag beta feature: charge density charlotte CFX 4 March 22, 2011 10:14
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
UDF in Fluent to Match Mass Flow at Pressure Outlet Jonas Larsson Main CFD Forum 1 April 29, 1999 11:44
