July 11, 2017, 08:32 |
3 phase setting (erodible soil, water, air)
Azril Hazim
Hi everyone.
I just need to know how best to model a pipeline on erodible seabed under influence of sea current & waves. Please refer attached sketches for details. I tried modeling it but currently face three problems: i) How to import geo-mechanical soil properties onto the erodible seabed? I know that Static Structural analysis allows importing soil properties from Engineering Data toolbox, but not sure how this can work in Fluent ii) How to include pipeline bouyancy effect into the design iii) How to use Open Wave Channel for more than 2 phases Input for parameters are: Wave length 280m, Wave height 13m, water depth 56m, T=14.76s Pipeline diameter 176mm, pipeline bouyancy 268N/m Soil shear stress 9.1e3 N/m3, soil density 2.77e3 kg/m3 Thank you! IMG_2738.jpg IMG_2737.jpg |
erodible soil, multiphase |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 2 | November 27, 2012 22:36 |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 0 | November 25, 2012 00:14 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 22:58 |
Boiling of water with hot air | Dr. Flow Squad | CFX | 2 | July 27, 2009 08:37 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
