COUPLED Solver Stability Issues
Old   July 5, 2017, 19:23
Default COUPLED Solver Stability Issues
Abhimanyu
abhi.jam22 is on a distinguished road
Hey guys,
I have been performing 3D URANS simulations for Re 3 million on NACA 4415 AR 12 Wing using COUPLED Solver on structured hexahedral grid. I started off by running steady state simulations first using the same solver and got satisfactory results. But when i try to run Unsteady simulations, the result diverges in the first step even though the grid is the same. My momentum urf is 0.2, pressure 0.3 for both steady and unsteady. I have been able to get the solver to run for momentum urf to be 0.05 but the time-variation of CL (lift coefficient) is not realistic.
Can anyone suggest a solution to this issue?
Any help is highly appreciated.
abhi.jam22 is offline   Reply With Quote
Old   July 5, 2017, 22:45
Lucky
You shouldn't be using that small of a urf for transient simulations. Run small time-steps with large urf's (all 1's). Set the courant number to super large value, i.e. 1e7.
Is this compressible or incompressible? Check your courant numbers (acoustic and convective respectively)..
Old   July 6, 2017, 00:43
Abhimanyu
Incompressible.
Old   July 6, 2017, 16:22
Lucky
Originally Posted by abhi.jam22 View Post
Incompressible.
Then check the convective courant number and make sure it's <2, preferably <0.5
coupled, fluent, vorticity, wing, wing tips
Reasons for decoupling the pressure and velocity computations highlando Main CFD Forum 36 April 10, 2017 11:41
Divergence detected in AMG solver: k, epsilon, pressure coupled Tanjina FLUENT 5 January 13, 2014 11:46
Divergence detected in AMG solver: pressure coupled n.jithin.1991 FLUENT 6 January 5, 2014 12:43
coupled solver wont work in star ccm+ richie Siemens 5 November 4, 2008 05:51
The seperated solver and coupled one summer FLUENT 0 July 5, 2006 16:06
