Anomaly during CFD analysis of Supercritical airfoil.
Old   July 3, 2017, 05:30
Post Anomaly during CFD analysis of Supercritical airfoil.
Moon Bakaya Hazarika
moon1808 is on a distinguished road
Hello everyone.
I am a student learning CFD using ANSYS Fluent 18. For a project, I am doing the CFD analysis of the GA(W)-2 supercritical airfoil. I have opted for Spalart Allmaras viscosity model,taken my fluid (air) as an ideal gas with a constant value of viscosity and taken 'pressure far-field' boundary conditions. I have taken my Mach number between 0.2-0.25, and taken gauge pressure as 0.
In order to get a converged solution, I have chosen the Coupled solver and activated Pseudo-transient analysis. I have done standard initialization of the cases and have set the number of iterations to 2000.
Once the solution calculation is started for higher AOA, the continuity solution residuals decrease till ~1500 iterations and the cl value increases to the required experimental level . Then all of a sudden the continuity residual rapidly increases and within 100 iterations the cl value drops rapidly beyond which it has more or less the same low value. I increased the number of iterations upto even 10000, and have observed that the continuity residuals oscillate with a very large amplitude (0.07- 1.4). This problem does not occur at lower angles of attack (below 8 degree AOA).
I am unable to upload the case right now as it is on another computer, but if anyone has understood it, request you to help me with this problem
moon1808 is offline   Reply With Quote
fluent 18, supercritical airfoil
Airfoil 2D cfd simulation Cocorito90 OpenFOAM Running, Solving & CFD 14 December 19, 2016 04:43
CFD Analysis of Airfoil at Mach = 0.0 Hybrid FLUENT 8 October 11, 2012 06:40
[ICEM] Importing cambered airfoil geometry to ICEM CFD kotimari ANSYS Meshing & Geometry 2 July 16, 2012 16:44
ICEM CFD Airfoil Tutorial Input Tom ANSYS Meshing & Geometry 1 September 25, 2009 07:50
FDM vs FVM vs FEM in CFD analysis ck5285 FLOW-3D 1 September 1, 2009 11:51
