July 1, 2017, 11:09 |
Simple model not matching calculated values
Rep Power: 9 |
I am doing a project for uni where I am trying to calculate the flow rate needed to create a certain pressure at the start of some pipework for a range of temperatures. The calculated values and real world test values show that when plotting temp against flow rate it should be a curve but the CFD values are coming out as a straight line. I have simplified the model to just a small section of straight pipe with a 90° elbow and laminar model but results are still showing a straight line. At lower temps/higher viscosities (-10 to 5°C) the calculated and CFD values match well but then when going to higher temperatures which is only from 5 to 20°C they start to separate with the calculated values curving up and cfd values staying straight. I know its bit of an open question but is there something simple I could be doing wrong? Its as if the software is ignoring the viscosity in some way. Just to add to this. I have simplified it even further to just a straight pipe so that there isn't anything else to worry about like bends and it is still doing this Thanks, Nick Last edited by Nick8529; July 1, 2017 at 11:23. Reason: more info |
Hot Isostatic Pressing - assigning packing density values to a FEA model | hybrid25 | ANSYS | 0 | May 3, 2016 10:26 |
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? | JuPa | CFX | 0 | December 22, 2015 07:44 |
Error in Two phase (condensation) modeling | adilsyyed | CFX | 15 | June 24, 2015 20:42 |
about Subgrid-scale model | impecca | OpenFOAM Running, Solving & CFD | 4 | December 20, 2013 11:36 |
Jump in epsilon values near the wall : low re k-epsilon model | malaboss | OpenFOAM Verification & Validation | 1 | February 1, 2013 17:36 |
