June 24, 2017, 10:59 |
Custom Field Function
Njit
Rep Power: 9 |
Hello
I need to write (d-axialvelocity/d-radialcoordinate)^2.5 in the custom field function to extract the data. However, custom field function in FLUENT is not accepting a decimal number(2.5) in power and gives absurd results in the extracted data. However it gives correct results for a whole number. Can someone help me in this issue and provide me way to write 2.5 in power while writing a function in the custom field function. Thanks in advance. |
June 24, 2017, 15:47 |
Lucky
Rep Power: 66 |
Try using pow 2 and sqrt.
Also check if the error is caused by neg numbers since ^2.5 would return imaginary numbers. |
cannot find grid field function in custom field function | mehdiataei | FLUENT | 0 | March 19, 2017 04:53 |
Mass Flow Rate Custom Field Function | AJoubert | FLUENT | 2 | March 23, 2013 08:50 |
Gradient of the Custom Field Function | oghazian | FLUENT | 2 | June 29, 2011 14:00 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
time step size in Custom Field Function | Tong | FLUENT | 0 | May 2, 2008 15:51 |
