Ukraine
Rep Power: 9 ![]() |
I am trying to simulate a NACA0012 airfoil that slowly rotates from Angle of attack=0 to AOA=1deg.
I'm doing this via a rotating mesh ( a circle around the airfoil that rotates at 1deg per second, and in between I use 500 timesteps. When I solve transient he converges to a wrongful Lift coefficient (but drag coefficient is correct). Then if I do steady state simulation at AOA=1 he gives me the correct result for both coefficients. I already tried to reduce the rotation speed of the airfoil, increase the amount of time steps, increase iterations/timestep, reduce time step size,... But nothing has a significant effect on the lift coefficient. Before I start the transient simulation I made sure to first solve static analysis to have a good estimation for the flowfield at AOA=0 Ma= 0,023 Re= 219.000 I use turbulence model: Transition SST because for the application a correct estimation of the transition point is important. Before I had exactly the same setup with Re=3e6 and then everything worked perfectly I hope somebody has some advice at what I could look at or anything I could be doing wrong here. |
rotating mesh, transient sst, turbulence analysis |
Inverse and Transient Heat Transfer Problem on commercial software: is it possible? | rogbrito | Main CFD Forum | 1 | February 19, 2019 02:11 |
Continuity Convergence Problem in CFX | cfd seeker | CFX | 2 | July 2, 2015 11:12 |
convergence problem with compressible flow | sarah l | FLUENT | 0 | July 1, 2015 15:47 |
Problem with convergence | Iman Sengupta | FLUENT | 12 | June 23, 2015 07:44 |
Transient Problem | Sundar | FLUENT | 1 | May 7, 2002 07:34 |
