June 19, 2017, 10:07 |
Saline solutions in FLUENT
I have to remain anonymous, I'm sorry.
Location: The Netherlands, Delft University of Technology
Rep Power: 9 |
Dear CFD-Online community,
I am trying to simulate a reverse-osmosis/osmosis system, it basically consists of two "pipes" next to each other with a membrane in between. In one pipe flow pure water and in the other flows salt water. The simulation is in 2D In fluent, the membrane is just a wall and I want to use a UDF to transport the salt ions over the wall like a membrane. The big issue here is to model the dissolved salt. I am currently trying to use a User Defined Scalar (UDS) to model the salt concentration in mol/m3. However I have not Idea how to implement this. I set a flux of the UDS on the inlet and it just follows mass transport equations, but I have no idea what to do with the outlet. I can only set either a constant value or a flux there, which is incorrect and thus yields incorrect results. Doe anyone have a better idea on how to tackle this problem? I'd be happy to elaborate on anything, if it is not clear enough, please tell me. |
January 17, 2019, 08:03 |
Lapis Bolt
Well reverse osmosis system is just the mess you should move to Faucet filtration system
What do you think about this But soon going to give it a try too. I have not used any Best RO water system before just heard this remarks from my community Last edited by lapis12; January 22, 2019 at 11:32. |
January 18, 2019, 04:26 |
Rep Power: 9 |
Wouldn't work. My goal was not to produce clean drinking water.
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Fluent 16.0.0 and Ubuntu 12.04 | fivos | FLUENT | 11 | January 8, 2018 14:39 |
Interesting problem: Parallel Processor VOF Fluent + Dynamic Mesh + System Coupling | spaceprop | FLUENT | 5 | September 2, 2014 10:43 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 17:41 |
multiple solutions using Fluent | Hanjie Lee | FLUENT | 3 | August 15, 2006 18:21 |
