June 18, 2017, 14:10 |
Multiphase Flow - Euler model switch to DPM?
Hello to the reader,
I have successfully used the Euler - Implicit Model for multiphase simulations of gas-particle flow. In the next stage of my project there is a need to introduce an electrostatic field that will charge the solid phase. 1. How do I use the results of my current model to proceed from here ? i.e., do I make a complete switch to a DPM model? Im afraid that the results would change drastically. 2. How do I introduce an electrostatic charge in Fluent? Is there a simpler approach than writing a UDF? Any comments/ suggestions on this matter are appreciated. Thank you for taking the time to respond. |
electrostatic force, euler model, multiphase |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 00:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Multiphase flow in a pipe with a CHT | wissal | CFX | 4 | June 12, 2017 12:15 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
