How to create solid to fluid interface in Fluent using an ICEM CFD mesh. |
June 14, 2017, 15:23 |
Edward Kraft
Rep Power: 12 |
I created a structured mesh in ICEM CFD and imported it in to Fluent. There's an interface between the fluid and solid and I'm pretty sure that is my problem. When I set my boundary conditions and run the simulation, I get messages saying I'm outside the temperature range (less than 1 Kelvin or 5000 Kelvin). With the same mesh and boundary conditions, I can run it perfectly using Star CCM+. So I feel that my problem is with the mesh solid to fluid interface? I import the fluid mesh first, then I append the solid. I then go to Mesh Interfaces, and create the solid to fluid mesh. In ICEM, I call the fluid interface Fluid_to_Solid and the solid interface Solid_to_Fluid. Any help would be greatly appreciated!
June 15, 2017, 12:59 |
#2 | |
Kushal Puri
Rep Power: 13 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 10:33 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
