Not having vortex sheddings when I should
Old   June 10, 2017, 08:52
Default Not having vortex sheddings when I should
aero_cfd is on a distinguished road
i am investigating an a 10 deg flapped airfoil, Re=6.75e5 , Mach=0.1 , y+<1 . using the K-omega SST turbulence model, pressure based solver with SIMPLE algorithm,2nd order schemes. in order to get the right Re number I changed in the viscosity which is 6.174e-05 , the velocity is about 34 m/s.
The issue I am having is that after running at post stall angles of attack, I don't have vortex shedding, the Cl max angle is 13 , when I run 14 and 15 i get convergence with the steady state but no shedding, 16 and 17 I don't get the convergence in steady state but it doesn't diverge , so when i start the unsteady solver i start with the unconverged steady results, which gives some highly turbulent flow with vortex shedding , but how much can these results be trusted ?
What may be the cause of not having the vortex shedding ?
Thank you !
aero_cfd is offline   Reply With Quote
fluent, shedding, turbulence model, vortex
Presenation of vortex strength and velocity concept? fruitkiwi Main CFD Forum 0 September 26, 2012 23:08
vortex cause pressure gradient or pressure gradient induce vortex? fruitkiwi Main CFD Forum 4 June 12, 2012 02:12
creating vortex core line aay023 Main CFD Forum 0 September 15, 2010 22:49
turbulent scales of forced vortex and free vortex lcw Main CFD Forum 3 September 1, 2005 14:40
