June 8, 2017, 07:37 |
Error when loading the solution
Rep Power: 9 |
Hi, I've got a problem. My solution was fine and everything was ok. But after I restarted the Computer I always get an error when loading my solution. After this all Results are unavailable in the setup menu. And I can't create Iso-Surfaces.
But the solution is still there because I can open it in the Postprocessor. But I need need it in the Setup. In English an Error has occurred in Fluent while applying the cx Statusinformation. The Cortex-Status and surfaces cannot be updated The Error: Ansys.Fluent.Cortex.CortexCommandFailedException: Ein Fehler ist in Fluent aufgetreten beim Anwenden der cx Statusinformationen. Der Cortex-Status und Oberflächen konnten nicht aktualisiert werden bei Ansys.Fluent.Cortex.CortexCommunicator.SendMessage (String msg, String msgKey, String errorMessage, Boolean waitForReply) bei Ansys.Fluent.FluentCommunicator.SetCortexState(Str ing state) bei Ansys.Fluent.Data.SetupData.UpdateCortexState(IFul lContext context) bei Ansys.Fluent.Data.SolutionData.LoadSolutionPoint(I FullContext context, Int32 iteration) bei Ansys.Fluent.Data.SetupData.LaunchFluentAndRead(IF ullContext context, Boolean batchMode, Boolean loadSolution, DataContainerReference fromContainer, Boolean internallyStarted, Boolean reuseSession, Boolean pendingMode, Boolean isRsmUpdate, Boolean solution_resume) bei Ansys.Fluent.Data.SetupData.LaunchFluentAndRead(IF ullContext context, Boolean batchMode, Boolean loadSolution, DataContainerReference fromContainer, Boolean internallyStarted) bei Ansys.Fluent.Data.SolutionData.LaunchFluentAndRead (IFullContext context, Boolean batchMode, Boolean internallyStarted) bei Ansys.Fluent.Commands.EditCommand.Execute(IFullCon text context) bei Ansys.Core.Commands.Concurrency.CommandWorkUnit.ex ecuteInContext(CommandContext subContext, IExecutionEngineCallback tracer) bei Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExe cute(IExecutionEngineCallback executionEngine, CommandContext subContext) bei Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execu te(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions) --- Ansys.Core.Commands.CommandFailedException: Ein Fehler ist in Fluent aufgetreten beim Anwenden der cx Statusinformationen. Der Cortex-Status und Oberflächen konnten nicht aktualisiert werden CommandName: Fluent.Edit(Container="Solution 2") bei Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext) bei Ansys.Fluent.Commands.EditCommand.InvokeAndWait(IP rotectedContext context, DataContainerReference Container, Boolean Interactive) bei Ansys.Fluent.Gui.GuiUtilities.GetLauncherSettingsA ndEdit(GuiOperationContext operationContext, DataContainerReference cref, LauncherEditMode editMode) bei Ansys.Fluent.Gui.OpenInFluentGui.Invoke(GuiOperati onContext context) bei Ansys.UI.GuiOperationContext.Invoke(GuiOperationMe taData operationData) bei Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction) |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 22:22 |
Solution Diverging with Trimmer Mesh | rietuk | STAR-CCM+ | 8 | February 27, 2013 05:50 |
Why 3D solid-pore geometry showing diverged solution? | Sargam05 | OpenFOAM | 0 | December 3, 2012 16:45 |
Analytic solution for 2D steady Euler equations | jojo81 | Main CFD Forum | 0 | October 15, 2012 13:05 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
