June 7, 2017, 15:09 |
"Track" a body position
Rep Power: 9 |
Hello Friends,
I am currently working in Vortex Induced Vibrations (VIV) on a cylinder. I am considering a 2d geometry, which means the cylinder is modeled as a circle immersed in a rectangular fluid domain. I wish to study the relation of inlet velocity vs. vibration amplitude, but for that I would need a way to "track" my circle position vs. time, or at least its center position. Do you know any way I could do that? Using a UDF maybe, what you guys think? Thank you for your time, Dbrin |
cylinder, positions, udf, viv |
[snappyHexMesh] dynamic mesh: rotating body with increasing/decreasing distance to fixed body | mo_na | OpenFOAM Meshing & Mesh Conversion | 3 | July 26, 2016 04:51 |
writing solid body position to a file - sixdof issue | fsaltara | OpenFOAM Post-Processing | 5 | May 26, 2016 07:49 |
position of body force on the momentum equation | lin | OpenFOAM Programming & Development | 2 | September 26, 2014 21:31 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 01:29 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 05:59 |
