Heat transfer through porous medium
Old   June 6, 2017, 09:32
Default Heat transfer through porous medium
myworkcfd is on a distinguished road
Hi
Iam trying to simulate the heat transfer through porous medium.
Air enters and leaves the porous medium(porous medium-bottom wall is hot).
I have created the model in GAMBIT.I have taken a big domain, have split it in to 3 regions,named the middle region as porous , while left and right of porous are fluids.
If I specify the both the interfaces (left and right of porous medium)as wall in GAMBIT , 2 walls and corresponding wall shadows are formed in fluent. I have specified the fluid as air.Specified the porous medium parameters also.The case is not converging in FLUENT.
If I do not specify the interface in GAMBIT, the case converges.
Which method is correct?
myworkcfd is offline   Reply With Quote
heat transfer in a porous medium ADK Mesh Generation & Pre-Processing 0 March 8, 2016 14:05
Heat Transfer in porous media debabrata.mahapatra CFX 2 July 17, 2014 17:59
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 18, 2014 00:45
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 14:14
