Shock not forming in Pressure Distribution of airfoil
Old   June 3, 2017, 14:44
Default Shock not forming in Pressure Distribution of airfoil
Al
spaceman776 is on a distinguished road
Hi, I am doing a CFD analysis of transonic (M=0.8) flow over a NACA-0012 airfoil at an angle of attack 2º as practice. I followed a Cornell tutorial on creating the geometry and mesh exactly but that was for subsonic flow of V=1. So I used the same mesh and geometry but I made changes in Fluent to account for compressibility and such. I used a C-Mesh that extends 12.5m on both sides of the origin (located on the tip of the trailing edge) with the airfoil length being 1m.
My setup:
General > Density-based solver and steady
Models > Energy On and Inviscid
Materials > Air > Density > Ideal Gas
Boundary Conditions > Inlet and Outlet are set to Pressure Far-Field with gauge pressure set to 0, M=0.8, and the x and y components set to the cosine and sine of 2º respectively.
Using the setup above I get the following results. It looks 99% correct but the bottom surface won't show any shocks for some reason. Here is what it should look like at 1.25º. I set it up for 1.25º to compare it with the prior link and the bottom surface still doesn't match correctly. I am not sure if I made an error when changing my setup from subsonic to supersonic. Anyone know what could be the cause of this? Thanks in advance!
spaceman776 is offline   Reply With Quote
how can make normal shock in the nozzle at inlet B.C : Pressure Far field SonicGhoul FLUENT 2 May 8, 2016 06:16
pressure distribution in water flow, differences in icoFoam and COMSOL deniggo OpenFOAM Running, Solving & CFD 14 September 30, 2010 04:48
plot pressure distribution on a section of 3D wing ROOZBEH FLUENT 3 April 21, 2008 04:30
Effects of gravity in pipe - pressure distribution Anthony Wachs FLUENT 2 July 25, 2001 08:07
Where can find airfoil data with pressure distribution or aerodynamic data Ahlo Main CFD Forum 5 January 12, 1999 23:45
