How to create vacuum in Fluent
Old   June 1, 2017, 11:08
Default How to create vacuum in Fluent
Bouras Oussama
bourasOussama is on a distinguished road
Hello All, How can vacuum be modeled in Fluent?
Thank you.
bourasOussama is offline   Reply With Quote
Old   June 1, 2017, 11:12
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
You will have to be waaaay more specific to get a useful answer...
flotus1 is offline   Reply With Quote
Old   June 1, 2017, 11:20
Bouras Oussama
I'm sorry .. I want to simulate a power coupler, inside the coupler there is the vacuum and outside there is air so I have to model the convection outside the coupler, the conduction in the material of the coupler and the radiation on the inside
So I will use the S2S model for radiation, but when I put nothing inside the coupler Fluent does not want to calculate the radiating faces so I need to model the vacuum
thank you
Old   July 25, 2018, 11:36
asdf;lkj
vijaybr1993 is on a distinguished road
Dear, Bouras Oussama
i have same problem i am new in fluent i wanted to create vacuum, if you found he solution request you to assist me
vijaybr1993 is offline   Reply With Quote
Old   July 26, 2018, 12:44
Mattia
Comi is on a distinguished road
Mine it's just a guess but, you could try to set the density of the internal volume very close to zero. I'm not sure how the solver wil behave though...
Comi is offline   Reply With Quote
How to create matching mesh zones so that periodic boundary can be created in Fluent cgoodale1 STAR-CCM+ 3 February 29, 2016 13:34
Create a curved surface/ plane in fluent ? tarkesdora FLUENT 1 September 15, 2014 15:04
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
