Setting up porous medium in fluent: flow and reaction
Old   May 30, 2017, 05:50
Default Setting up porous medium in fluent: flow and reaction
Hugo BROSS
ScienceLiker is on a distinguished road
Hi everyone,
I'm modelling drying in fluent and i am facing a problem. i will be very grateful if you can help.
I m modelling the biomass drying in a cylinder.
1. How to define biomass in fluent?
2.The cylinder is full of biomass and hot air flows from bottom to top.
how can i model it?
I want the biomass to be stable and hot air converts water liquid into water vapor.
Thank you in advance.
ScienceLiker is offline   Reply With Quote
Old   May 30, 2017, 09:02
KaLium's Avatar
Kal-El
KaLium is on a distinguished road
What kind of biomass?
In some cases porous zone might be good estimation (for flow conditions/pressure lost).
I think there is no easy solution for drying. Perhaps you could put the biomass moisture content into UDM and solve the drying process with UDF.
KaLium is offline   Reply With Quote
drying; porous media, flow
Modelling CO2 adsorption (porous media + surface reaction) asfrallego FLUENT 1 October 27, 2024 09:15
gas-solid reaction Fluent Sara28 FLUENT 2 April 8, 2022 04:35
An efficient procedure to solve many design points for flow with reaction in fluent jumaah FLUENT 4 May 4, 2017 21:10
porous medium and reactions Valeria FLUENT 1 July 10, 2009 04:58
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
