Solid Boides in the Flow
Old   May 29, 2017, 16:01
Default Solid Boides in the Flow
nikos_ is on a distinguished road
Hello everyone,
I want to simulate the following case. Three parallel solid disks with fluid between them. The upper disk is moving downwards with a given axial velocity and the downer disk is fixed. Gravity is neglected.
I assume that i can describe upper and downer disk motion making a DEFINE_CG_MOTION udf.
My main problem is that i don't now what type of motion/boundary condition should i have for the middle disk and more general the interface between the disk and the fluid. It is supposed that the disk shall moved downwards due to a force applied to it by the fluid pressure. So i can't give my self a value of velocity to this disk and it somehow occur itself. Is it possible having a type of free, unconstrained solid body motion?
One option i thought of, is obtaining the velocity of the nodes that are in the upper edge of the middle disk and then give that value to the disk itself. Is it possible to do so and does that seems reasonable?
Ideally the boundary conditions would be:
1)Left and right surfaces : pressure outlets.
2)Upper disk: moving with given negative y velocity.
3)Downer disk: remain fixed (zero velocity)
Thank you very much.
Nikos
nikos_ is offline   Reply With Quote
fsi interface, fsi problem, solid body motion, solid fluid interaction
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow Jing Main CFD Forum 8 October 5, 2018 18:02
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Flow over a flat plate as an immersed solid hamed.majeed CFX 4 September 8, 2016 15:40
Using CFX for solid thermal analysis (no flow modelling) Maksim1990 CFX 1 December 6, 2014 04:52
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 12:41
