May 27, 2017, 08:42 |
anisotropic conductivity for a fluid phase
Rep Power: 15 |
Hello everyone !
I'm trying to solve thermal conductivity in a gas mixture and I would like to set a radial conductivity that is different than the axial one. For a solid, it is possible to do that by selecting "cyl-orthotropic" in the conductivity tab in materials. However this option does not show up for a fluid material.... I also can't see how to do it in a UDF since it is not possible either to select "user-defined anisoptropic conductivity"... Does anyone know if there is a way to work around it ? Thank you ! GG Last edited by gghazal; May 29, 2017 at 04:02. |
January 23, 2018, 16:38 |
Ernest Gonza
Hi gghazal
I am facing the same problem. Did you find a way to work with anisotropic conductivity for a fluid phase? thank you. |
January 24, 2018, 11:53 |
Rep Power: 15 |
Hello
One workaround is to consider a "virtual" porous media with a porosity equal to 0 and setting the solid to have the same properties of the fluid. The effective conductvity will be equal to that of the porous media (it is possible to set an anisotropic conductivity) GG |
anisotropic conductivity, fluid phase |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
iteration questions in discrete phase | iknowjesus | FLUENT | 4 | March 13, 2015 07:07 |
primary phase (liquid) out of the gas outlet | ChisK47 | Fluent Multiphase | 0 | January 23, 2014 07:59 |
Gas dissolution from liquid phase with CFX | Roger Young | CFX | 2 | May 6, 2008 08:37 |
