Computed Pressure Drop is lower than experimental data |
May 16, 2017, 17:27 |
Hello Everyone,
Objective: To simulate Gas-liquid 2 Phase flow in FLUENT based on experimental data, and compare with respect to experimental data for channel with sudden area of expansion. I'm running the FLUENT 2 Phase flow (gas(Nitrogen)-liquid(Water)) Eulerian-Eulerian multi-phase model, RSM (Reynold's Stresses 5 equation model) model for turbulence calculations. it's 2D steady-state analysis. Boundary Conditions: inlet: pressure inlet, Outlet: pressure Outlet, Volume fraction is used for consideration between phases. (Values for boundary conditions are taken from Experimental calculations) Outcome: Computed Pressure Drop is lower than experimental pressure drop across sudden expansion. Why is it showing lower pressure drop compared to experimental value? How can I get exact pressure drop value for expansion channel? |
May 17, 2017, 00:56 |
Lucky
Rep Power: 66 |
Are the differences even significant?
You are using nearly a dozen models that try to mimic actual reality, if you want to exactly match results then either improve the models or stop using models altogether. You're using a multiphase model, a turbulence model, the properties are modelled, you're modelling it as steady state, etc. The list goes on and on. Of course this is assuming you made no mistakes along the way. |
May 17, 2017, 10:41 |
#3 | |
I activated multiphase eulerian eulerian model, and for catching turbulence in pipe, because the Reynolds number for hydraulic diameter is high. For turbulence I decided to use RSM, that's all. These are I guess basic models which we need to activate. There is no involvement of energy equation. The model is stable and it's converging, because the inlet mass flow rate is equal to outlet mass flow rate, by speculation based on the surface monitors. Also, I used k-epsilon per phase model, but still pressure drop is significantly low. Value, for example, for 5g/s mixture flow rate (in terms of experimental analysis) is 0.5 kpa, while fluent shows 0.12 kpa. Sent from my iPhone using CFD Online Forum mobile app |
2-phase flow, eulerian eulerian, fluent, multi phase flow, reynolds stress model |
Wind tunnel Boundary Conditions in Fluent | metmet | FLUENT | 6 | October 30, 2019 13:23 |
Pressure drop in pipe flow with Large Eddy Simulation | xerox | FLUENT | 1 | October 16, 2019 09:55 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 06:35 |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 16:00 |
