partially premixed combustion heat release rate per cell
Old   May 16, 2017, 09:04
Default partially premixed combustion heat release rate per cell
sqek is on a distinguished road
Hello
I am modelling large-amplitude thermoacoustic oscillations in FLUENT, using a transient simulation, and the partially premixed combustion model.
I am using the c-equation chemical equilibrium model, with compressibility effects and non-adiabatic treatment, with a c2h4-air mixture.
I would like to calculate the rate of chemical heat release (in W or W/m3) on a cell-by-cell basis (in such a way that I could plot contour maps etc of heat release), in order to see how the phase difference between heat release and pressure varies throughout the combustor.
Is there a way to do this with a field function or UDF please?
Thanks very much
sqek is offline   Reply With Quote
combustion, partially, premixed, unsteady
Problem with total heat transfer rate aswathy_raghu FLUENT 9 April 21, 2022 11:36
Non-premixed combustion: local heat release rate LB FLUENT 1 April 28, 2021 23:11
combustion heat release Anna_p Main CFD Forum 0 June 20, 2013 12:40
Partially Premixed Combustion or Finite-Rate allamarein FLUENT 0 June 2, 2009 15:20
Help on premixed combustion heat seaspace Main CFD Forum 2 May 27, 2003 06:28
