Turbulent natural convection
Old   May 12, 2017, 17:08
Default Turbulent natural convection
Juan D. Carreño S.
JuanDCS is on a distinguished road
Hi guys, im doing simulations of free convection over heat spheres in high Rayleigh numbers, the thing its that when i use some turbulent model the heat goes up, im focusing in use low reynolds number models, and still heat its high, so what you guys can advice me to do? so i can get betters results
JuanDCS is offline   Reply With Quote
Old   June 8, 2017, 14:07
Juan D. Carreño S.
Hi guys,
I change the limit viscosity ratio to values lower than 1000 and the results of heat transfer were good, but the residuals dont converge to the value i set, this dont down more that 1e-03, what can be the problem and how i do to get my converge criteria?
Old   June 15, 2017, 21:12
Default Initialization of low-re-ke
Juan D. Carreño S.
Hi guys,
I've been doing some modifications to my simulation, the sphere that i have been simulating its in a box with temperature of 298 K, the sphere have 308 K and the top its a free surface, i have the top as pressure outlet, when i use the turbulence model (Abe-Kondoh-Nagano) appear the advertising of turbulence viscosity ratio to xx cells, when i modified the values of turbulent kinetic dissipation and turbulent dissipation rate in the initialization, the simulation solve the flow very well, but i dont know if the modification of this value its alright? will appreciate the help its for my degree work
free convection, heat transfer, low re k-e, turbulence heat flux
How to Model Natural Convection Flow in Porous Media at openFOAM? AmirBaqa1987 OpenFOAM 0 December 27, 2016 02:23
Specifying turbulence parameters for natural convection on vertical flat plate abu250feldman FloEFD, FloWorks & FloTHERM 2 May 5, 2014 14:42
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 05:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 05:58
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 19:43
