CFD Simulation of a Rocket Engine Nozzle: Divergence Issue (Want to see nozzle plume)
Old   May 12, 2017, 15:25
Default CFD Simulation of a Rocket Engine Nozzle: Divergence Issue (Want to see nozzle plume)
Vinayak Deshpande
VinayakDesh is on a distinguished road
Dear All,
I am trying to perform a turbulent (k-epsilon) compressible flow simulation through a rocket engine nozzle with the following conditions:
Inlet P: 2 MPa, T: 900 K
Outlet: Vacuum
Here is my mesh and boundary region:
Inlet is : nozzle entry, and outlet is: the domain beyond the nozzle exit.
An image can be found here:
https://gyazo.com/bb7e493437eab39a5ae9f861f728be34
The turbulence model I use is k-epsilon, and the Operating condition is set to 0
Gauge Pressure at Inlet: 2 MPa, and outlet: 0 Pa
I am not sure why this solution seems to diverge, I think I am defining the boundary condition wrong. What must I do to fix this?
The mesh is pretty dense (4mm max size) - The nozzle outlet is 82 mm
I would appreciate if someone could shed some light on this error and help me fix this issue.
Kind Regards,
VinayakDesh is offline   Reply With Quote
Old   May 12, 2017, 16:46
Default Dear admin, please close this thread
Vinayak Deshpande
I have figured it out, thank you
Old   February 28, 2018, 22:07
Song Guoqing
Incend1a is on a distinguished road
hi
I have recently solve the resemble problem as you.
here is my case set
turbulence model: S-A
inletressure inlet 3Mpa,1000K
outletressure outlet 1.01KPa,300K
wall:idiabat wall
mesh is fine.
I am not sure why this solution seems to diverge,either
can you tell me how to do with it,thank you
Kind Regards
Incend1a is offline   Reply With Quote
Old   February 1, 2022, 06:24
Alessandro
Alessandro Z is on a distinguished road
Hi can you please explain to us how did you solve the problem?
Alessandro Z is offline   Reply With Quote
Old   February 2, 2022, 21:57
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
https://www.youtube.com/results?sear...le+simulation+
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
compressible, exhaust, flow, nozzle, rocket
CFD Salary CFD Main CFD Forum 17 January 3, 2017 18:09
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 20, 2015 00:40
engine simulation CFD: what's a good book? Geoff Main CFD Forum 0 August 23, 2001 11:04
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 22:10
Reactor simulation using CFD takes to the Internet Mark Brennan Main CFD Forum 0 April 16, 1999 06:57
