VoF Model, miscible fluids, mass transfer rate
Old   May 12, 2017, 08:50
Question VoF Model, miscible fluids, mass transfer rate
Yu Lu
yulu is on a distinguished road
I'm simulating a situation where a channel is filled with one static fluid (fluid 1) and another fluid (fluid 2) (which is miscible to the one filling the channel) is injected into the channel to displace the first one.
I care about the interfacial phenomena at between these two fluids So I'm planning using laminar VoF model (which works fine for my immiscible cases).
For simple fluids, for example a glycerol solution (Say 86% wt.) as Fluid 1 and water as fluid 2. The only place I found to put the diffusion/mass transfer between these two fluid is the "mass" tab in the phase interaction. What exactly is this value I should put in? I was guessing a constant mass transfer rate but in the Fluent manual it says constant rate is not available for VoF model.
Some suggestions on how to work out this value for my situation or the actual value I should use and its source will be much appreciated! Thanks a lot!
yulu is offline   Reply With Quote
Old   March 24, 2018, 11:59
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
You can add a variable source term through a UDF.
hamed.majeed is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Solver for Multispecies Mass Transfer induced Domain growth/shrinkage MonoC OpenFOAM Running, Solving & CFD 1 March 13, 2016 08:41
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
