How to plot volume flow rate of inlet and outlet in fluent? |
May 11, 2017, 04:57 |
TEH WEI PENG
Rep Power: 9 |
Hi everyone, i need to plot a( flow increase curve)graph of inlet and outlet volume flow ratw versus time, but i not sure the method i use are correct or not. I create a surface monitor of inlet and outlet volume flow rate but i get weird result, for example the inlet is 2 the outlet are -2 .
The target Of result are looks like the picture below: Anyone can help me ASAP? |
May 11, 2017, 06:48 |
Kal-El
Rep Power: 9 |
May 11, 2017, 11:39 |
TEH WEI PENG
Rep Power: 9 |
My target of data is outlet volume flow rate must multiply the intake air by 15 times. What is mean by the negative outlet flow rate?
The integral velocity magnitude in fluent also have unit m3/s , is it represent volume flow rate too? |
May 11, 2017, 23:04 |
#4 | |
Lucky
Rep Power: 66 |
Integral of velocity over a surface should have units of m^3/s because it has units of velocity times units of area. The integral of velocity magnitude over a surface is not the volume flow rate. A quick counter-example is I have infinite velocity parallel to a surface, the integrated volume magnitude would be infinite but there would be no flow across the surface. The integral of the normal component of velocity with respect to the surface over the area is the volumetric flowrate, by definition. |
May 12, 2017, 03:52 |
#5 | |
TEH WEI PENG
Rep Power: 9 |
May 12, 2017, 20:37 |
Lucky
Rep Power: 66 |
You need to run more than one simulation and record the inlet and outlet volume flow rate. Then you make the plot in excel for example.
volume flow rate |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 05:58 |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Volume flow rate boundary condition in OpenFOAM | mayank.dce2k7 | OpenFOAM Running, Solving & CFD | 13 | August 11, 2014 20:16 |
