Comparison of LES based turbulent quantity with RANS based turbulence
Old   May 11, 2017, 05:16
Default Comparison of LES based turbulent quantity with RANS based turbulence
mali28 is on a distinguished road
I am using Fluent to do simulation of air flow in a geometry. I want to compare the turbulence level obtained from RANS models with LES model. In RANS I can get turbulence intensity, kinetic energy etc.. but in LES which parameters do I use?
Fluent has resolved UV, VW, UW Reynolds stresses for LES but I do not understand what this is.
mali28 is offline   Reply With Quote
Old   May 11, 2017, 17:57
Lucky
If you do not understand what resolved UV, VW, UW Reynolds stresses are then you do not understand how LES works and I would encourage you to slow down, stop what you are doing, learn the basics, and only then proceed.
Turbulence intensity is just a normalized turbulent kinetic energy. If you know what turbulent kinetic energy is, it is straight forward to calculate the resolved part of the turbulent kinetic energy from the filtered velocities (the RMSE X-velocity, Y-velocity, and Z-velocity). Alternatively you can also back-calculate it from the resolved part of the Reynolds stresses but in my opinion it is already easy enough to do.
The tricky part is getting the contribution of the turbulent kinetic energy of the subgridscales. It depends slightly on what subgrid scale model you are using. There's a very simple algebraic formula that involves a filter length and subgridscale turbulent visosity (it's basically the subgridscale model itself), but it only makes sense if you know how LES works in the first place. For Smagorinsky, the subgrid kinetic energy is the turbulent viscosity divided by the sgs filter length and then squared.
First you must understand what turbulent intensity is, what turbulent kinetic energy is, what LES does, and what is the output of LES. It's my personal opinion, but I refuse to teach people how to do anything if they don't understand what it is or how it works because they often go on to draw naive conclusions. And then they teach it to others.
Naive question about turbulence and LES Renato Main CFD Forum 1 October 5, 2005 00:01
caracteristic turbulence time in LES skippy FLUENT 0 September 16, 2004 11:51
Rankings of RANS based Turbulence Models Abhijit Tilak Main CFD Forum 0 September 10, 2004 13:10
RANS results for LES Li Yang Main CFD Forum 5 June 17, 2002 06:34
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 05:24
