Ocean pressure field problem
Old   May 11, 2017, 04:04
Default Ocean pressure field problem
Louison
luisao is on a distinguished road
Hi everyone,
I am working on simulation in the ocean. I would like to have a bubble to rise from 100 depth. I succeed doing this with the gravity field and the intersticial tension between air and water.
My problem is about my pressure field. I would like to have, for my water and my bubble, a pressure of 1 bar at the surface and, gradually, a pressure of 10 bars at 100 depth.
I thought the gravity field would have done that.. (with the definition of the based pressure at the surface.)
The pressure is important in my case because my bubble has a diameter of 20m.
I can specify my demand if it's needed.
I would like to thank you in advance for your help.
luisao is offline   Reply With Quote
Old   May 11, 2017, 11:20
Louison
I finally found the problem.
You just have to activate the Operating density on the Operating Condition menu.
#air, #bubble, #gravity, #ocean, #pressure
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Problem with Fluctuationg Pressure Field in opneFOAM (Repeated Post) owayz OpenFOAM Running, Solving & CFD 1 August 9, 2012 14:24
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Problem with the pressure field using interFoam zoune OpenFOAM Running, Solving & CFD 20 February 4, 2008 19:42
