suggest meshing setting for a flow across grille simulation
Old   May 9, 2017, 14:38
Default suggest meshing setting for a flow across grille simulation
Qkarl is on a distinguished road
Hi, i'm now running simulation about the flow across grille with a rotating fan behind it. But, i got a divergence error in fluent and i think it is mostly due to the mesh setting. Can anyone guide or suggest a mesh setting for my case. I did attached few picture of my grille and its cross section view and the whole model here. thanks in advance. the gap between the grille is around 7mm
Qkarl is offline   Reply With Quote
Wind Tunnel Flow Simulation Mass Flow BC Issue ledelman SU2 4 August 3, 2014 19:38
Fan flow simulation in open air idiroft CFX 5 June 10, 2014 08:34
is free meshing or mapped meshing is best for flow problems shanu Main CFD Forum 0 February 18, 2010 12:58
[Other] is free meshing or mapped meshing is best for flow problems shanu OpenFOAM Meshing & Mesh Conversion 0 February 18, 2010 12:56
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 17:29
