May 6, 2017, 17:19 |
Heat exchanger with PCM.
abdulhamit
Rep Power: 11 |
Hi friends.
my english is google translate. sorry I'm trying to do a pcm analysis. But I have not been able to do it until now. I made some solutions but it was always diverting. I have added some pictures of the results. I used different commands each time. But it did not. http://imageresim.com/images/58588884045835199054.png http://imageresim.com/images/79235627896774529537.png http://imageresim.com/images/20884217028920206034.png I made a mistake in the analysis above. I corrected my mistake, but still did not solve it. The end result and the video are down. I think The result is false. Please slow down the setting. http://imageresim.com/images/97555723968852594088.png https://www.youtube.com/watch?v=X6Sf...ature=youtu.be I think the problem is timestep. "time-step" needs to be reduced. But this is a big problem for time-related problems. Because the experiment I have done is one hour (3600 seconds). In the ANSYS training file, it is necessary to set "time step" as follows. http://imageresim.com/images/52029361928234405599.png Characteristic length= min. element size According to this formula my time step in my tutorial is 0.001. I think impossible because 3 600 000 time step is 3600 second. And 10 iterations at each time step. 36 000 000 iteration My problem is at below. http://imageresim.com/images/21237057014294932401.png http://imageresim.com/images/14036083610042285437.png http://imageresim.com/images/93399837100234001895.png http://imageresim.com/images/16941704906234095570.png The simulation is laminar, Gravity is downward but flow upward I think it is false. the picture is at 20 second http://imageresim.com/images/72994045873690356067.png http://imageresim.com/images/20766371701911633990.png inlet=0.09337 m/s 60C outlet=pressure-outlet pcm wall; h=20 w/m2K temp=25C wallthickness 0.007m and iron solidwall; h=20 w/m2K temp=25C I use symetry. PCM specificition is OK. solution metod= simple, coupled, simplec but Fluent did not solve. I usually use simplec. Standart initilization. @Tapeworm I think you should use laminar, you should look https://www.cfd-online.com/Wiki/Turbulence_intensity What is Reynold number your problem in the inlet? My guess is that the time step should be very low in PCMs. |
May 8, 2017, 04:19 |
Rep Power: 9 |
Thank you for linking this one to my thread! As I also mentioned in my thread, I will use laminar flow as well. I also have some troubles with the time steps. I think you should use the adaptive settings as well. The problem is that the simulation is taking way too long... With a time step size (s) of ~0.01 it will take days/weeks to fulfill a simulation. That is only for the discharge process, which takes roughly about 1.5h in real time to complete. The charging process takes about 5-6h real time to complete... |
May 8, 2017, 08:00 |
Rep Power: 9 |
It seems like the mesh of the PCM was a critical point for my problem. I haven't been ablr to run the full simulation yet, but the beginning of the simulation looks much better after increasing the number of cells in the PCM.
I suggest you try do the same, focus on the PCM! Will get back later on when I got some more information. |
tapeworm |
Double pipe heat exchanger | mohcin | FLUENT | 21 | June 18, 2016 15:19 |
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent | medogalal | FLUENT | 3 | December 30, 2015 05:28 |
transient source term | strakakl | OpenFOAM | 38 | November 19, 2013 02:18 |
Modelling serpentine heat exchanger | andbe | ANSYS | 0 | September 30, 2013 10:08 |
Concentric tube heat exchanger (Air-Water) | Young | CFX | 5 | October 7, 2008 00:17 |
