FLUENT, VOF - Sea wave propagation decay
Old   May 4, 2017, 11:35
Lightbulb FLUENT, VOF - Sea wave propagation decay
federica strati
fstra is on a distinguished road
I am having the following issue for a while, hope somebody here can help.
I am using Ansys 16.2, and employing open-channel-flow-BC to simulate the generation of a periodic wave at the inlet. The computational domain is 30m long and water depth is 5 m.
The simulation is correct for the case of large waves (such as H=2 m and L=12m), with dt=0.005s and refined mesh at the interface with size of 0.25 m.
However, when trying to simulate smaller wave, I get waves with a strong decay effect after less than 1 s of simulation. This would happen for: H=0.2m, L=3m, dt=0.001s and reduced mesh sized of 0.005 m.
In both cases, turbulence model was set to relizable k-eps.
It is worth noting that such a behavior does not happen when viscosity effects are neglected. Thus, it can probably be a problem related to the turbulence model.
If any of you could help indicating the most suitable turbulence model I would really appreciate.
Thanks in advance.
fstra is offline   Reply With Quote
Old   May 4, 2017, 11:45
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by fstra View Post
Thanks in advance.
I am not sure to understand the details of your flow problem...but if you need to simulate the details of the onset of an unsteady phenomenon you definitely cannot use RANS/URANS ...
I can suggest to see if you have enough computational power to do an LES.
However, it would be better if you provide more details.
FMDenaro is offline   Reply With Quote
Old   May 5, 2017, 02:50
federica strati
Thank you for your answer.
I have to simulata transient flow. I am not interested in the detail on the interface, but to have a fully-developed sea wave field.
I have understand the problem is related to the turbulence model: for a small wave, viscosity effects are significantly higher and the wave decays. My question is whether there is a suitable turbulence model to avoid this, or else how can I modify the parameters of the turbulence model in order to have a reduced effect on the viscosity at the water/air interface.
Old   May 5, 2017, 04:05
Your problem is critical in terms of modelling... URANS implies by definition an effect of the model on all wavenumbers of the flow.
Again, I suggest to see if you have enough computational power to do an LES. Fluent allows you to use the dynamic Smagorinsky model. The key is to produce a quite fine grid for your problem
Old   May 8, 2017, 07:54
federica strati
I was hoping there would be a simpler way to achieve a reasonable solution.
Last hope: if the problem is related to the predominance of viscosity effect at the interface, is there a way to impose a sheer-stress free condition at the free-surface with VOF? Maybe when defining the phases..? Do you have any suggestions with this regard?
Thank you in advance
Old   May 8, 2017, 09:05
The physical viscosity effect is overwhelmed by the modelling effect of the RANS formulation.
fluent, viscosity-effects, vof, wave decay, wave generation
VOF wave getting damped. arun7328 STAR-CCM+ 16 July 8, 2019 16:06
Refinement for VOF wave arun7328 Siemens 4 January 21, 2019 09:57
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
vof method of wave height gtfeng STAR-CCM+ 2 June 8, 2013 03:32
Propagation of Waves with VOF Panayotis Prinos FLUENT 0 December 7, 2000 07:10
