Compressed Air filling in near vacuum chamber |
May 3, 2017, 12:23 |
Bharatvaaj
Rep Power: 9 |
There is a 20L sphere with an inlet pipe.
I have modeled input data for different time steps (discrete) there is data for velocity, mass flux, mass flow, pressure, temperature, density for time step increments of different orders (i.e. 0.001, 0.0001, 0.00001, 0.000001 s) These are discrete values, so I generate a graph of mass flux vs time step in excel and create a trend line and get a mass flux equation varying with each time step increment. I create a UDF function in C based on this massfluc(t). I input this at the inlet boundary (2D edge at the end of pipe). either temperature is diverging, or non-physical solution. I patch the sphere and tube initially with 300 K and 0.4 bar pressure. I initialize with standard initialization and gauge pressure as 21bar. I need to track the expansion process of the inlet air inside the sphere. What am I doing wrong, do you have a simulation strategy This is a transient, compressible flow simulation |
air filling, compressible flow, gas filling, gas pump, transient |
Air entrainment model setup for spillway | oajor | FLOW-3D | 4 | November 17, 2016 13:02 |
Boundary conditions for compressed air | raunakjung | Main CFD Forum | 0 | September 27, 2016 02:01 |
compressibleInterFoam case – a flat wall air cavity filling up with water | Zeppo | OpenFOAM Running, Solving & CFD | 0 | October 3, 2015 11:01 |
Hydrogen Air combustion in a combustion chamber | popi | CFX | 7 | July 11, 2007 19:40 |
moving water from a chamber using air | Matt Mason | CFX | 0 | December 2, 2003 20:46 |
