May 2, 2017, 15:44 |
Fluid Structure Interaction (FSI) - 2/Way
Hello.
My work consists of two concentric cylinders in order to the internal cylinder is an solid cylinder with fixed angular velocity and the external cylinder is a fixed domain being the stationary fluid domain. The normal procedure are transfer the forces from fluid (Fluent) to solid body and receive from solid body (Mechanical) the displacements. Additional that, I need to transfer the angular velocity from rigid body (Mechanical) due a torque to fluid domain (Fluent) through the interface, but I can't do that. Please, someone could help me to resolve it? Is it possible to create a external routine to do that? The APDL could be an option? Thanks. |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Simple FSI (fluid structure interaction) Problem | kilroy | Main CFD Forum | 0 | January 7, 2015 15:42 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
Fluid Structure interaction (FSI) | osirous | FLUENT | 5 | July 5, 2011 16:38 |
Fluid Structure Interaction and OpenFOAM capabilities | paka | OpenFOAM Running, Solving & CFD | 1 | June 6, 2007 14:56 |
