April 27, 2017, 07:35 |
6 dof settings for VAWT
Apun
Greetings everyone!
While working on VAWT 2D simulation, I want to see the effect of wind velocity on blades for which 6 dof solver is needed. However I am not able to decide what settings to use. I'll list a few settings that I have tried: 1. I have created named selection for the fixed domain (rectangular) and rotating domain (circular, slightly larger than the rotor diameter, this domain has three airfoils/blades which are to be studied/rotated by wind velocity) 2. I have created mesh interface at the edge of the above mentioned domains (in fact I have been able to successfully complete sliding mesh solution, using sliding mesh technique) I am new to UDF's and 6dof solver so am at a complete loss as how to proceed further. In 6 dof solver settings: 1. Should I make the above mentioned rotating domain as "deforming"? 2. Should I set the airfoils/blades as "rigid body"? If yes what would be the UDF (as its compulsary to hook UDF in rigid body option)? I doubt this because from the few macros I am aware of, all are used if a predetermined motion is to be given to the body, like sinusoidal. But in my case, I merely want it to be free to rotate about z axis, no other motion to be allowed. 3. Should I tick "implicit update" option? 4. How many (and which/where) "dynamic mesh zones" should I create? |
6 dof, dynamic mesh, vawt, vawt wind turbine, vawt wind turbine energy |
Lift and Drag coeff change with V 16 and 13 PISO for same mesh file and same settings | arunraj | FLUENT | 0 | June 2, 2016 22:43 |
Fluid-Solid Interface Settings for a Rotating Water Container | r.mojtaba | CFX | 4 | October 14, 2013 19:01 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
thermoBaffleProperties object settings | calim_cfd | OpenFOAM | 0 | October 4, 2011 10:17 |
The concept of DOF in fluid mechanics and CFD | bearcat | Main CFD Forum | 8 | May 27, 2007 18:02 |
