April 25, 2017, 14:58 |
2D Squeeze Flow
Rep Power: 9 |
Good evening everyone,
I'm facing a difficulty in a case of a 2D squeeze Flow. More specific, i study the flow between just 2 straight plates, one stationary and the other moving towards the other. I have Pressure outlet boundary conditions at left and right boundaries. Ansys Fluent is able to calculate the solution when i set as boundary conditions the velocity fields at the top ( negative u_y, zero u_x) and bottom (zero u_x,u_y) boundaries. But when i try to simulate the top and bottom boundaries by walls, one moving and one stationary, solution cannot be obtained. There is reverse flow at boundaries and zero mass flow rate. Has anyone any idea what i'm doing wrong in the case of the walls? Thank you very much in advance. |
2d flow, squeeze flow, walls boundary conditions |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 07:12 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 09:33 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 08:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 06:57 |
