Boundary conditions for volume increase through mesh deformation
Old   April 25, 2017, 12:38
Default Boundary conditions for volume increase through mesh deformation
Lennart
elmo555 is on a distinguished road
Hey,
I'm trying to set up a problem in Fluent that essentially consists of a moving wall, mesh deformation, and thus a volume change causing under-pressure, and flow into the domain.
I'm confused about the boundary conditions I should choose for the inlet. Please have a look at the attached drawing for more details.
My idea is to use a pressure-inlet and prescribe 0 gauge pressure (since I think there is ambient pressure at the open boundary). Then the volume change in the left part should cause an under-pressure, and the flow (red arrows) should occur.
Are my ideas right? Any comments are welcome!
elmo555 is offline   Reply With Quote
moving mesh, no outlet, volume change
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
FFD shape deformation for 3D wing not changing the mesh lwc24 SU2 Shape Design 5 August 1, 2019 16:17
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
