DPM_BC smillar to Filter
Old   April 25, 2017, 03:20
Question DPM_BC smillar to Filter
Yoon
touyet is on a distinguished road
Hi
currently I'm working on filter efficiency. and I already know penetration Efficiency of filter in each particle size.
To try this on fluent simulation, I want put udf about DPM in porous jump.
My plan is generate random number on each particle (like 0 to1) and if particle has low random number than filter penetration Efficiency, the particle considered to pass through (PATH_ACTIVE ; ) (I checked this Pass Active condition in my doamin, but it seems to reflect particles in porous jump BC)
Else, particle considered to Capture (PATH_ABORT ; )
Problem is.. How can I modifie my UDF to some particles can passing through the porous jump plane
touyet is offline   Reply With Quote
Old   April 25, 2017, 03:21
Yoon
DEFINE_DPM_BC(bc_filter,p,t,f,f_normal,dim)
int a;
/* Different Efficiency by Particle Diameter && Penentration Efficiency */
if ((P_DIAM(p)==0.000000005) && (P_USER_REAL(p,0) >= (0.266*32000)))
{p->gvtp.n_trapped+=1;
a=PATH_ABORT;}
else if ((P_DIAM(p)==0.000000020) && (P_USER_REAL(p,0) >= (0.750*32000)))
a=PATH_ABORT;}
else if ((P_DIAM(p)==0.000000050) && (P_USER_REAL(p,0) >= (0.885*32000)))
a=PATH_ABORT;}
else if ((P_DIAM(p)==0.000000100) && (P_USER_REAL(p,0) >= (0.922*32000)))
a=PATH_ABORT;}
else if ((P_DIAM(p)==0.000000300) && (P_USER_REAL(p,0) >= (0.881*32000)))
a=PATH_ABORT;}
else if ((P_DIAM(p)==0.000000780) && (P_USER_REAL(p,0) >= (0.616*32000)))
a=PATH_ABORT;}
else
{p->gvtp.n_Escaped+=1;
a=PATH_ACTIVE;}
return (int) a;
My Udf for filtering now and Active condition doesn't work as I intended
Plz someone help with this UDF
regards.
Old   April 26, 2017, 03:01
ctw987 is on a distinguished road
touyet touyet touyet touyet touyettouyettouyet
ctw987 is offline   Reply With Quote
dpm, filter, path_, porous jump
dynLagrangian SGS model tidal_Tom OpenFOAM Running, Solving & CFD 43 November 16, 2022 06:13
Accumulating Dust on a Filter Cartridge WalterW CFX 21 May 26, 2020 07:23
how can use the LES filter? (laplace filter and anistropic filter) ethan oh OpenFOAM Running, Solving & CFD 11 December 26, 2018 03:37
LES Filter in Smagorinsky model on inhomogenous grids Ivan Main CFD Forum 1 October 25, 2012 12:30
Filter lifetime aszbestos FLUENT 0 February 13, 2002 08:59
