April 21, 2017, 21:15 |
VF Phase does not converge
nashim
Rep Power: 9 |
Hi, I am modelling cavitation in a t-junction pipe. All of my residuals converge apart from the vf phase which plateaus.
Why does it not converge? EDIT: could it be due to that fact I am running this as steady ? |
April 24, 2017, 02:44 |
SinaJ
Rep Power: 16 |
Something that you should find out, before looking in other details, is that whether your problem has steady state solution or not. For example, filling a tank has no steady state solution, and water flow in a tank with an outlet might have a SS solution. I don't know your problem's details, but I don't think it has a SS solution.
Then, I would make sure I have correct boundary conditions, and initial condition (correct patching of the domain if needed for the second phase). Try to reduce the volume fraction under-relaxation factor to something around 0.25, and see if you notice a change or not. |
April 24, 2017, 04:29 |
nashim
Rep Power: 9 |
Hi, yes it does converge when ran transiently, agreed, this system is not in a steady state.
Thank you for the response |
cavitation, convergance, mixture model |
FVUS (Finite Volume Utilities and Solvers) / Wildkatze (solver) Updates | arjun | Main CFD Forum | 30 | July 22, 2017 03:27 |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 05:43 |
Gravity/Buoyancy/Buoyancy reference density in two phase flow | sharifi | CFX | 10 | June 9, 2014 10:23 |
Specifying phase on both sides of a Boundary Condition? | rassilon | OpenFOAM Running, Solving & CFD | 3 | November 11, 2009 00:41 |
Converge problem for multiphase flow | Jen | FLUENT | 4 | July 20, 2005 16:52 |
