Random number generation for filter
Old   April 18, 2017, 20:30
Default Random number generation for filter
Yoon
touyet is on a distinguished road
Hi
currently I working on filter efficiency. and I already know penetration Efficiency of filter in each particle size.
For try this on fluent simulation, I want put udf about DPM in porous jump.
So, My plan is generate random number on each particle (like 0 to1) and if particle has low random number than filter penetration Efficiency, the particle considered to pass through (PATH_ACTIVE
Else, particle considered to Capture (PATH_ABORT
Is anybody help me about this Udf or recommend reference about it?
touyet is offline   Reply With Quote
Old   April 19, 2017, 04:00
Yoon
I wrote some udf code but ther is error ( "'bc_filter' : not all control paths return a value" )
Is anybody know about what is the problem??
regards
Old   April 19, 2017, 04:01
Yoon
UDF Particle Capture in Prous jump by Filter Efficiency.
#include "udf.h"
#include "stdlib.h"
DEFINE_DPM_BC(bc_filter,p,t,f,f_normal,dim)
/* Define Particle Random Number */
int ns;
int nc=TP_N_COMPONENTS(p);
/* Random Number Genreation 0 to 1 */
srand(time(NULL));
for (ns=0; ns < nc; ns++) {
real A=rand();
if(p->type==DPM_TYPE_INERT)
/* Different Efficiency by Particle Diameter */
if (P_DIAM(p)==0.000000005)
/* Penentration Efficiency */
if(A <= 0.266)
{return PATH_ACTIVE;}
else
{return PATH_ABORT;}
if (P_DIAM(p)==0.000000020)
if(A <= 0.75)
else
if (P_DIAM(p)==0.000000050)
if(A <= 0.885)
else
if (P_DIAM(p)==0.000000100)
if(A <= 0.922)
else
if (P_DIAM(p)==0.000000300)
if(A <= 0.881)
else
if (P_DIAM(p)==0.000000780)
if(A <= 0.616)
else
return PATH_ACTIVE;
else
Old   April 20, 2017, 03:07
Yoon
I develope my code and the New one is below.
problem 1 is how can i get new property for random number (currently I put random number in temperature but it is problem)
problem 2 when I compile and use this code all particle aborted
How can i deal with it??
regards
Yoon
#include "udf.h"
#include "stdlib.h"
DEFINE_DPM_INJECTION_INIT(Random_Temp, I)
Particle *p;
/*Standard Fluent looping Macro to get particle streams in an inejction using steady particle tracking*/
loop(p,I->p)
/* Put Random Number Genreation (0 to 1) in Particle Temp Value */
srand(time(NULL));
P_T(p) = rand();
/* Different Efficiency by Particle Diameter && Penentration Efficiency */
if (P_DIAM(p)==0.000000005 && P_T(p) >= 0.266)
else if (P_DIAM(p)==0.000000020 && P_T(p) >= 0.750)
else if (P_DIAM(p)==0.000000050 && P_T(p) >= 0.885)
else if (P_DIAM(p)==0.000000100 && P_T(p) >= 0.922)
else if (P_DIAM(p)==0.000000300 && P_T(p) >= 0.881)
else if (P_DIAM(p)==0.000000780 && P_T(p) >= 0.616)
else
return PATH_ACTIVE;
return 0;
Old   April 20, 2017, 03:09
ctw987 is on a distinguished road
hello touyet! You're a random addict? Is the StarCraft race also random?
ctw987 is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
ERROR #001100279 has occurred in subroutine ErrAction. smnaryal CFX 11 December 20, 2017 17:32
random number generation hwet Fluent UDF and Scheme Programming 9 February 29, 2016 20:35
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
