Strange results from boundary conditions.
Old   April 17, 2017, 20:31
Default Strange results from boundary conditions.
shafkat
SHAFKAT91 is on a distinguished road
I have a given a fluent file by a friend. I am trying to find the same results he got. But I am noticing something strange with the boundary condition. If the initial temperature and boundary temperature is same, it gives the one type of results. But if the initial temperature and boundary temperature are different it gives a different set of results. The results are same for the temperature difference of 1000k and 1K. Can anyone please tell me why this is happening. Is this single precision, double precision type of problem?
SHAFKAT91 is offline   Reply With Quote
Old   April 18, 2017, 01:44
Lucky
Check to make sure the results for each are converged.
Old   April 18, 2017, 02:01
shafkat
That is also a strange thing. My friend who did this problem said that the solution should converge after 10 to 12 iteration, but all I see is a flat curve with no change. Can you suggest me why this keeps happening?
Old   April 18, 2017, 14:42
Lucky
Flat curve of a solution variable or the residual? Flat curve of the solution would mean it's already converged. If flat residuals, which residuals?
Did you load the .dat from your friend and try to continue running? Then the solution would already be converged and you would just continue running.
If you initialize it back to the same initial condition that your friend used, you should get the same result as your friend.
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 12:14
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
