Can i take contours from Custom field function i defined ? |
April 17, 2017, 03:45 |
Rahul Ohlan
Rep Power: 9 |
hello
i defined a custom field function for secondary flow velocity and i wanted to take the contours out of it. but the function i defined is not showing up in display>contours field ! is it compulsary to degine the custom field function prior to the calculation ? pls help |
April 17, 2017, 19:11 |
#2 | |
Lane Carasik
Rep Power: 15 |
April 17, 2017, 23:37 |
Rahul Ohlan
Rep Power: 9 |
I've defined a function for solid secondary flow velocity as
V = sqrt((phase-2 y velocity)^2+(phase-2 z velocity)^2) i.e a simple function making use of the already available field functions in fluent i need to take contours out of this equation ! |
April 18, 2017, 14:39 |
Lucky
Rep Power: 66 |
You should be able to make contours from custom field functions. I just tested it on Fluent v15 and v17.
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
Force Report help~ or maybe Custom Field Function | sailor | FLUENT | 0 | April 13, 2011 04:45 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
