Solving complex geometry with compressible flow |
Gonzalo
Rep Power: 16 ![]() |
Hi all:
I have a problem simulating a complicated geometry with a complex flow inside it witn FLUENT. With complex I mean that it has a complicated path to follow and in some places i could be detached, so there could be some reversed flow. The inlet Mach N° is 1.13 and I have a pressure outlet at the exit. My BC's area as follow: for inlet: Mass-flow-inlet, a total temperature and I set a static gauge pressure for the firs iteration, and for the outlet a static pressure . I'm using a Density based formulation, air as an ideal gas, SST-kw for turbulence, 2nd order for the spatial discretizacion, coupled solver with pseudo transient formulation. The problem is that in the inlet, the solution can't reach the specified Mach N° and the convergence for the continuity is not as good as I wish (5e-2), and I don't know why. The other problem is that, the total mass balance is not accomplished, sometimes the outflow is 50% higher than the inlet. I can't understand this!!! I have some experience with fluent solving compressible flow but in non confined places, but in cases with confined compressible flow my experience is little. Can someone guide me on what I can do to solve this problem? Thanks in advance |
Gonzalo
Hello:
no one can help me with this? Thanks |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 09:48 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 08:35 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
