How to stop Fluent from printing out all boundary conditions?
Old   April 6, 2017, 20:42
Default How to stop Fluent from printing out all boundary conditions?
Yangyao Ding (Roy)
dingyangyao1995 is on a distinguished road
Hi Everyone,
Whenever I update a boundary condition using TUI, for example,
define bc mass-flow-inlet
Fluent will print out all existing mass flow inlet surface, which I have hundreds in my model.
Is there a way to turn off the auto printout?
Thank you!
dingyangyao1995 is offline   Reply With Quote
Old   April 7, 2017, 10:37
Gonzalo
gfoam is on a distinguished road
Hi:
you could make a journal to set all the parameters of mass-flow-inlet in your model, ie:
define bc mfi inlet1 parm1 param2 ...
or do this in the TUI, but you need to know all the zone names you have to set in your model. Regards
gfoam is offline   Reply With Quote
Old   April 7, 2017, 14:49
Yangyao Ding (Roy)
Hi, thank you for your reply.
What i meant is that, even if I do the entire TUI command to set new condition in one line, fluent still print out all the existing bc names in a square bracket, which is very annoying. Is there a way to turn off that prompt?
Old   April 7, 2017, 15:01
Gonzalo
Mmmm, dont think so. Because Fluent is listing the zone names with mass flow inlet BC's specified on it so you can choose one of them. Are you trying to specify the same mass flow on alll of them? Or, are there groups with the same mass flow? If so, then you can specify the mass flow on one o some of them and then use the Copy BC command to copy the settings on all BCs. Regards
Old   April 7, 2017, 18:00
Lucky
The define bc mass-flow-inlet command is designed to work this way.
To avoid the listing, you should use the more primitive command:
define/boundary-conditions/set mass-flow-inlet "ID" blah blah blah
Old   April 8, 2017, 13:50
Yangyao Ding (Roy)
This is exactly what I am looking for!
I wonder, where did you get these sort of information? From years of using fluent or is it from the fluent documentation?
Old   April 9, 2017, 03:18
Lucky
It was from a few minutes of just typing commands into the TUI to find the right command. It was based on a hunch that surely the people/developers at Fluent were not dumb enough to print the entire list of surfaces when there is no need to, especially since Fluent is designed to run in batch mode. The rest was elbow grease and willing to get your hands dirty to fix the problem.
tui
CFD analaysis of Pelton turbine amodpanthee CFX 31 April 19, 2018 19:02
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
Gridgen's boundary conditions and Fluent famarcfd FLUENT 0 December 12, 2009 11:00
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
