Boundary Conditions for a room with recirculating air |
April 4, 2017, 10:05 |
rohit
Rep Power: 9 |
I want to design a room which has a fresh air inlet, outlet, and a recirculation zone so that certain amount of air can be recirculated back into the room. I have my inlet as a velocity inlet, my outlet as pressure outlet, but I am really confused with the recirculating path boundary condition. The geometry of the room is attached. Can someone please help me with this problem. what boundary conditions should i use so that i can have a required amount (say 10% or 20%) of return air. |
November 4, 2019, 08:53 |
mousa
https://www.learncax.com/knowledge-b...n-ansys-fluent
use this help |
July 26, 2021, 12:19 |
#3 | |
Collins Ogbodo
icepak? > #f what could be the problem |
July 26, 2021, 13:07 |
mousa
July 26, 2021, 16:31 |
#5 | |
Collins Ogbodo
I have some more questions if you don't mind. I have a model for indoor AC The AC unit has two inlets (inlet1- for the recirculation of air indoor. inlet2- for getting fresh air from outside) and one outlet into the room can I write a UDF that can help switch between AC inlets in fluent? |
February 27, 2023, 02:47 |
Recicularion in ANSYS fluent
Chethana G D
Dear all I am working on a problem which includes recirculation unfortunately with the above command I am unable to activate the recirculation. Could you please elaborate how to enable it?? Iam using ANSYS 15
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 18:19 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
