Rysiek z Klanu
Rep Power: 9 ![]() |
Hi Everyone,
Hi Everybody, Can someone help with with the following issue? I have made in Inventor 2017 a pipe for the analysis in ANSYS fluent. I made it as assy of a few bent pipes etc. I created two bodies - one outer (pipe itself) and inner as "air". After implementing igs file into Fluent, seletring pipe as "solid", inner area as "fluid" I had some problems with meshing. Below please find communicates that I get. Would appreciate any help. Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details. Te rest of errors are attached as jpeg. ![]() |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[Other] Hex meshing problem DM12 | patrick | ANSYS Meshing & Geometry | 7 | January 9, 2015 07:21 |
[GAMBIT] Problem in meshing a pipe within a cylinder | l14766 | ANSYS Meshing & Geometry | 7 | May 14, 2013 17:24 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
[Commercial meshers] problem meshing two interacting volumes | banerji | OpenFOAM Meshing & Mesh Conversion | 0 | December 14, 2009 15:59 |
