/solve/initialize/init-instantaneous-vel command disabled
Old   April 2, 2017, 15:34
Default /solve/initialize/init-instantaneous-vel command disabled
nashim
nashim.chowdhury is on a distinguished road
When trying to initialize a flow field for the use in LES, the command
is disabled
The commands below are available in this menu.
Those followed by "*" are currently disabled.
compute-defaults/                               open-channel-auto-init*
dpm-reset                                       reference-frame
fmg-initialization                              repair-wall-distance
hyb-initialization                              set-defaults/
init-flow-statistics                            set-fmg-initialization
init-instantaneous-vel*                         set-hyb-initialization
initialize-flow                                 show-time-sampled*
levelset-auto-init*                             vof-patch-smooth-options/*
list-defaults
How do I go about enabling this option ?
nashim.chowdhury is offline   Reply With Quote
Old   April 3, 2017, 10:17
Lucky
You use the command while still in RANS mode, i.e. before you activate LES. You also need an existing RANS solution.
Old   April 3, 2017, 10:23
nashim
Yes I ran a preliminary k-e realizable run, and had not switched to LES yet.
hmm, still confused
Old   April 3, 2017, 10:48
Lucky
hmms how about...
Check if you are in steady or transient solver. It might be disabled for steady solver. You might need to switch to transient (but still RANS) and then you can type in the command. Be very careful though because as soon you switch to LES, Fluent will lose the k solution.
edit* nevermind I just checked, it is there for steady and transient.
If that is not it, I wonder if maybe someone disabled that command on your setup...
Old   April 3, 2017, 10:54
nashim
Running on a transient solver, this is strange, will investigate to see if someone disabled it.
thank you for the responses !
Old   April 4, 2017, 09:15
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Fluent version?
sbaffini is offline   Reply With Quote
Old   April 4, 2017, 09:41
nashim
Version 16.2
Old   April 4, 2017, 16:47
Lucky
I checked on v15 v16.2 and 17.2. The option is present for steady and transient for all, at least on my setup.
Old   April 5, 2017, 12:21
nashim
Could it be possibly due to the fact that I am using the academic student license?
Old   October 3, 2024, 10:57
wangjiangnan is on a distinguished road
Have you solved it yet? I have the same problem as you
wangjiangnan is offline   Reply With Quote
How to average different instantaneous data in CFD-POST directly? neuzhaopeng ANSYS 0 July 22, 2015 10:58
How to average different instantaneous data in CFD-POST directly? neuzhaopeng ANSYS 0 July 22, 2015 10:42
DPM,define the instantaneous droplet injection vel Stan FLUENT 0 July 12, 2008 08:32
Instantaneous and Mean Vectors looks same anindya FLUENT 0 June 14, 2005 02:42
Mean vel. or RMS Vel.? Nathan CFX 0 September 30, 2002 04:23
