Workbench Parametric Runs - Obtaion .csv files Automatically
Old   March 30, 2017, 10:44
Default Workbench Parametric Runs - Obtaion .csv files Automatically
nikos_ is on a distinguished road
Hello, I’m facing some difficulties regarding the parameter design in Ansys Workbench.
More specific I have one input geometric parameter and I wish to obtain .csv files which contain Pressure and Radius values at nodes for each value of the geometric parameter in order to plot them and compare them. I can do it if i open Results each time and export manually the .csv file with the values i need for each value of the parameter.
But I can’t figure out how to achieve saving the .csv files automatically for each value of the parameter so that i won't have to do export manually each time.
Should i make any configurations in Solution tab or Results tab ?
Is it supposed that Workbench saves them independently? I have read similar threads but I couldn’t reach to a solution.
I attach the schematic of my project and parameter set.
I will be grateful if anyone could help.
nikos_ is offline   Reply With Quote
Old   March 31, 2017, 09:27
Paritosh Vasava
vasava will become famous soon enough
For now I can think of two options:
You can add a command that exports solution data in Execute Commands. You should see this option in Calculation Activities. You should be bit careful about file overwriting.
The other option is bit manual and I guess you already know this.
  1. Create all the design points
  2. Update the project (make sure that you see green tick-marks on design points)
  3. Open each design point and export data manually
vasava is offline   Reply With Quote
Old   April 2, 2017, 10:21
This is indeed what i am trying to achieve. Could you maybe send me some information about the command you are refering to ?
The manual option is working but i am trying to automate the process.
Thank you.
Nikos
Old   April 3, 2017, 04:14
Paritosh Vasava
I have never tried this my self. But I know that you will have to make a macro in the
Execute Commands window. You can follow these instructions to create macros. Also here is the complete list of commands.
I hope you will find appropriate help. Do share your experience.
ansys fluent 16.2, export data, parameter set, parametic study
Parametric study by Ansys Workbench Sahar FaPerhu ANSYS 17 August 23, 2017 04:29
Creating many def files for parametric study Chander CFX 5 April 2, 2012 11:48
Parametric runs and Optimization in ANSYS (Conjugate Heat Transfer Problem) cp_jef ANSYS 0 May 30, 2011 05:08
Changing CFX.def in WorkBench Parametric analysis sodjaj ANSYS 1 August 23, 2010 11:04
ICEM A* or workbench for parametric modeling? Sudharshani CFX 0 June 30, 2009 01:40
