How to set sinusoidal electric current for volume of electrodes in Fluent?
Old   March 27, 2017, 07:26
Question How to set sinusoidal electric current for volume of electrodes in Fluent?
ngoctm is on a distinguished road
Hello everyone,
I want to assign the sinusoidal current for volume of electrodes for representing the three-phase AC supply to the electrodes. The current inputs, were specified as equal in magnitude but with a phase lag of 120^{o}.
i=Im.sin(2\pi.f.t+\phi)/V_{electrode}
Could you help me to setup this input.
Thank you in advance.
NgocTM
ngoctm is offline   Reply With Quote
Old   April 4, 2017, 01:42
Hello Everyone,
I have received an advice to set up this function. But I don't know which is the correct syntax for sin function between 2 functions below:
#include "udf.h"
#define FREQ 50 /*Hz*/
#define PI 3.1415
DEFINE_SOURCE(j_source,c,ct,ds,eqn)
real CURR = 1200.0;
real VOLTA = 180.0;
real VOLUM = 0.002157;
real source1;
source1 = VOLTA*CURR/VOLUM*sin((2.0*PI*FREQ*CURRENT_TIME+90.0)*PI/180.0);
ds[eqn] = 0.0;
return source1;
Or
#include "udf.h"
#define PI 3.1415
real CURR = 1200.0;
real VOLTA = 180.0;
real source1;
source1 = VOLTA*CURR/VOLUM*sin(2.0*PI*FREQ*CURRENT_TIME+90.0*PI/180.0);
ds[eqn] = 0.0;
return source1;
Could you please give me some advice?
Thank you in advance!
NgocTM
Old   August 7, 2017, 16:59
Aureliano Sancho
SanchoBuendia is on a distinguished road
Hi, I'm trying to build a model, rectangular channel with cathode on the inside and anode on the outside, but I don't know how more that. Could you help me?
SanchoBuendia is offline   Reply With Quote
Old   August 1, 2022, 09:54
sina
sina_sls is on a distinguished road
Originally Posted by ngoctm View Post
Hello everyone,
NgocTM
Hello
I want to set sinusoidal value of electric potential (MHD module) for a wall, first i try expression but i faced to error :
Error: wta(2nd) to string_eq
Error Object: __expr__
then i try Profile and UDF profile , but agian i faced to problem , when i use them it consider the wall to insulated.
Could you help me how can i set sinusoidal value for current density ( Electric Potential MHD) ?
Best Regards,
sina_sls is offline   Reply With Quote
Old   August 2, 2022, 02:40
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
show your code, show compilation log, explain the error in details
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 2, 2022, 03:14
sina
Thank you for your response,
this is my UDF profile code that when i select it for a wall , MHD module consider the wall as insulated:
#include "udf.h"
#define PI 3.141592654
DEFINE_PROFILE(current_density,thread,position)
face_t f;
real t = CURRENT_TIME;
begin_f_loop(f,thread)
F_PROFILE(f,thread,position)=13*sin((2*PI/0.04)*t);
end_f_loop(f,thread)
This is expression :
13*sin((2*PI/0.04[s])*Time)
when i use it and then go to MHD module Box it show this error :
and fluent didn't run and show this :
======Message from the Cortex Process========
Compute processes interrupted. Processing can be resumed.
Old   April 14, 2023, 11:46
Bulgaria
Niicho is on a distinguished road
Hello sina_sls,
Did you manage to solve your problem? I am experiencing a similliar issue! thank you in advance!
Niicho is offline   Reply With Quote
ac electrical current, electrodes, mhd
[ICEM] ICEM Scripting Issues tylerplowright ANSYS Meshing & Geometry 33 September 27, 2021 17:35
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 10:53
how to set such B.C. in Fluent? Sherri FLUENT 1 January 12, 2006 13:32
