Falling Water Drop Simulation (VOF)
Old   March 22, 2017, 10:34
Default Falling Water Drop Simulation (VOF)
Maksim
qorka is on a distinguished road
I simulate a water drop falling on the solid surface, but when the drop is near the bottom, it changes its form (see attachment)
I use surface tension and static contact angle = 90°
I use VOF explicite model with implicite body force
I tested this case with different solution methodes:
1)PISO-Green Gausse Node Based - Body Force W. - Second O. Momentum - Geo Reconstract
2)PISO-Green Gausse Node Based - Body Force W. - Second O. Momentum - Compressive
And also with PRESTO! pressure scheme
but the results are equal
Please, help me
qorka is offline   Reply With Quote
Old   March 22, 2017, 11:48
valerie
Tigrgrou is on a distinguished road
Could you try a contact angle of 0 to see the effect on the result?
Tigrgrou is offline   Reply With Quote
Old   March 22, 2017, 12:05
Maksim
I set angle = 0
but the result is same
Old   March 22, 2017, 13:11
valerie
Do you have the same result if you switch the wall adhesion formulation and/or a finer mesh near the wall?
Sent from my ALE-L21 using CFD Online Forum mobile app
Old   March 22, 2017, 13:29
Maksim
I turned it off
The results are better, but i think it is still wrong
The mesh is fine
0.05 mm
that means 40 elements in diameter of drop
Old   March 22, 2017, 14:08
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Is this a problem? Are you sure that the deformation you see can not be a physical effect? What exactly did you expect and why?
The mesh is fine
No offense, but I heard that phrase a lot. And usually when it is stated like that the assumption is wrong. Your mesh might be fine enough to resolve the droplet itself, but it might be too coarse to resolve the scales of the impact.
flotus1 is offline   Reply With Quote
Old   March 22, 2017, 14:11
valerie
If the mesh cannot b e refi.end because of calculaation time, eulerian wall film can be coupled with vof.
I agreed with flotus1. The mesh refinement should br tested.
Old   March 22, 2017, 14:13
Maksim
Which the physical effect? Can you this explain from the physical point of view?
I think that circle must not be deformed before contact with the wall
it was falling 95% of the path with perfect shape, and near the wall it decided to change the shape?
I don't think so
Old   March 22, 2017, 14:31
flotus1's Avatar
Alex
Is your droplet falling in a vacuum? Concerning the cell size: only one way to find out.
Old   March 22, 2017, 15:23
Maksim
The mesh was refined by 66%
0.05 mm ->0.03 mm
Problem is the same (see att.)
i think that my mistake may be in setting of parametres or so on, because it changes shape always in the last row of cells
what can i change ??
Old   March 23, 2017, 03:28
flotus1's Avatar
Alex
This does not convince me that the mesh you are using is fine enough to have no qualitative effect on the solution. For example I would argue that the distance between the two contact points is ~12 cells in both simulations.
If you can not afford a proper global mesh refinement study, it is sufficient to refine the mesh locally in the contact region.
Concerning the physical validity of the phenomenon you observe: you still did not answer the question if your droplet is falling in a vacuum. If there is a fluid surrounding the droplet, a similar deformation can actually occur under certain circumstances.
See for example http://pubs.rsc.org/en/content/artic.../SM/C4SM02474E and the references.
Looking at the pressure and velocty contours outside the droplet might shed some light on this issue.
Old   March 23, 2017, 07:17
Maksim
Velocity in this paper is greater then 10 m/s
I have vel. less then 1 m/s
I tested mesh 0.01 mm, that means 200 elements in diameter of drop
And as i have already said, the problem is not in mesh, because the changes appear ONLY IN LAST ROW OF CELLS
in every case, that's why problem in case options, such schemes, URF and so on
can anybody help me with advice ?
Old   March 24, 2017, 05:04
valerie
Do you run the simulation in 2D?
I tried in 3D and I do not observe the behavior you mentioned.
Old   March 24, 2017, 05:06
Maksim
I tested only 2D
Sent from my Lenovo K50-t5 using CFD Online Forum mobile app
Old   March 24, 2017, 05:19
valerie
it could be the problem, specially if you use planar 2D solver
Old   March 24, 2017, 05:20
Maksim
And i can`t resolve it?
Old   March 24, 2017, 05:51
valerie
if you expect a solution that has physical meaning, your simulation has to be more representative of your real problem.
If it a spherical bubble, you can try the 2D axisymetry solver or 3D solver.
Old   April 6, 2017, 04:46
Maksim
i have built the same case but in 3D, but if i set in CFD post 3 contours and see XZ and YZ planes, i see the same effect
Old   April 9, 2017, 12:01
Maksim
up this topic
Old   February 16, 2018, 05:05
Maksim
update:
after discussion with ANSYS support it is clear a limitation of VOF method. they recommend to use Euler models and change BC for water phase to slip.
Why the water is flowing along the wall by VOF model? jing113cn Fluent Multiphase 29 February 28, 2018 03:57
Simple VOF simulation failure wilandlane FLUENT 0 May 31, 2016 18:02
question about the simulation of air jet into water with VOF JU Yuanyuan FLUENT 0 August 19, 2012 21:52
Mass conservation problem in mixing tank multiphase simulation rockewan FLUENT 0 April 6, 2010 13:34
Simulation of a free falling wedge into water 2D nico765 OpenFOAM Running, Solving & CFD 3 January 11, 2009 03:47
