Area weighted average Temperature surface monitors |
March 20, 2017, 10:17 |
Ashwath Vaidhyanathan
Rep Power: 10 |
Hi All !
I am working on CFD analysis of PCMs, while doing the solidification/melting analysis of a cuboid block of pcm with one side wall and one top wall and others being adiabatic walls. I gave the top and side wall's BC as the following: Heat transfer coefficient: 28 W/m2-K Free stream temp: 288.15 K and did hybrid initialisation and gave the patch temperature as : 317.15 K Now i was getting Area weighted average Temperature as a text file, my question is the data shows a gradual decrease from time step 1 when the temp is 297.678 to time step 25200 when the temp is 294, shouldn't the temperature decrease happen from 317.15 K, why is it happening from 297.678 K ? |
March 20, 2017, 11:29 |
morceau
Rep Power: 9 |
try standard initialization
March 20, 2017, 12:58 |
Rep Power: 10 |
Hi
Thanks for your reply, I tried standard initialisation, but got same results, i think i have figured out what the problem is, so i saved data files at each time step and found at time: t=0, Temperature =317.15 K t=1, Temperature = 297.73532 K t =2, temperature =297.73385 K So basically for t=0 to t=1, there is a very rapid decline in temperature and after that temperature sips slowly with time, any inputs or solutions to this ? |
March 20, 2017, 21:16 |
morceau
Rep Power: 9 |
well....decrease your time step then
1s is definitely too long |
Area weighted or mass weighted average | SAM | Main CFD Forum | 31 | April 30, 2018 05:12 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
area weighted average | xisto | OpenFOAM | 0 | April 21, 2011 07:33 |
area weighted average | anif hidayatullah | Main CFD Forum | 2 | April 7, 2010 14:47 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
