Squeeze-Hagen Poiseuille Flow- Continuity Convergence Failure-Reverse FLow
Old   March 18, 2017, 06:25
Default Squeeze-Hagen Poiseuille Flow- Continuity Convergence Failure-Reverse FLow
nikos_ is on a distinguished road
Good Evening. I study a case of a film of fluid (oil) that is being squeezing and rotated simultaneously by 2 disks (top and bottom). In the attached files there is my geometry and mesh. The 2 disks move both in z direction ( in the presence of an axial velocity) and in theta direction ( in the presence of an circumferential velocity u_theta=angular_velocity * radius). Therefore I have a combination of couette and hagen poiseuille flow. The thickness of the film is 1.5 mm and the outflow of fluid ( squeeze out) is happening at inner and outer radius.
The boundary conditions I insert to Ansys are the following :
Top Disk: Moving wall- Components : Constant u_z and velocity field u_x and u_y which has been occurred by analyzing circumferential velocity to Cartesian coordinates (Ansys doesn’t allow giving a combination of moving and rotational wall, neither giving velocity components in polar coordinates).
Bottom Disk: Moving wall- Components : Constant u_z and velocity field u_x and u_y which has been occurred by analyzing circumferential velocity to Cartesian coordinates (reverse direction of circumferuntial velocity of the Top Disk ).
Inner Radius : Pressure outlet at 101325 Pa
Outer Radius : Pressure outlet at 101325 Pa
The main problem is that Ansys can’t solve the case because continuity equation can’t be converged. There is reversed flow in both Pressure Outlets and I can’t understand why.
Do you have any idea why this is happening and how to overcome it ? I have try many combinations of finite elements focusing mainly in the elements near outlets but still problem can't be solved.
Thank you a lot in advance!
Ps: I import the x,y velocity field in ansys top and bot disks by a point type profile. In a script I generate N random points and calculate the velocity components, then print them to a file.profile which I import to ansys.
nikos_ is offline   Reply With Quote
convergence failure, fluent, reverse flow, squeeze
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Hagen Poiseuille flow in circular micro-ducts freeform Main CFD Forum 0 November 7, 2010 16:13
Reverse Flow at Rotating Pipe Outlet vismech STAR-CCM+ 1 August 11, 2009 11:38
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 23:18
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
